Diatone DS-3000 owners thread
OK, so I thought I might start with my experience so far.
I bought DS-3000’s from Hifido in Japan about six weeks ago and had them shipped to my home in Australia. This cost a small fortune, as you would expect at 52kg each, but Hifido did as they always do and the Diatones arrived in perfect condition. During that 6 weeks I have been away from home for 3 weeks, so only now starting to get a real feel for them.
From the start I was surprised at a general lack of bass response. Given the specs say that they go right down to 25hz, this caught me a little off guard. I don’t need thundering, wall shaking bass, but I do like a nice full, warm sound. Initially, they sounded rather thin. I know these and other Diatone speakers are well known for the surrounds of the woofers hardening as they age. The Hifido listing stated that the surrounds had been treated to soften them. When they arrived, the surrounds seemed mostly soft, but with some harder areas. Perhaps further treatment is needed? I also noticed that the surrounds on the upper bass driver seem to be very hard. I’m not certain if these surrounds are made from the same material as the woofer, but they do feel like they could do with the same treatment.
Not sure if it‘s my aging ears, but when there is even the slightest harshness in high frequencies, it’s really quite uncomfortable for my ears. My early testing with the Diatones certainly had this issue.
I’m well aware that with any speakers, they rarely show their best in the first position you place them in the room. So I started playing with the placement. My listening room is small/medium size, carpeted floor. I don’t as yet have dedicated stands for these speakers as I wanted to try different positions first. I initially placed them on the floor, either side of the cabinet housing the rest of my gear, front baffles in line with the front of the cabinet. This left approx 20cm gap to the wall behind. The result was as described above. Thin on bass and harsh highs. The imaging was pretty flat too. From there I moved them forward and back, including right out into the room about a meter from the wall. With all this there was some variation, but broadly results weren’t much different. I then tried them with the stands from my Wharfedale Linton Heritage speakers which the diatones are replacing. These certainly aren’t the right dimensions for the Diatones but were an opportunity to elevate them on quite a solid and heavy stand. To be honest, the results were much the same again.
After a bit of thought, I remembered that when I was in my teens, my father bought a pair of AR speakers. They were a sealed box design as are these Diatones. I recalled that when he bought them, the salesman told him they were designed to be placed against the wall, in fact the user manual stated exactly that. I then placed the DS-3000’s on the floor as close to the back wall as I could.
WOW! All of a sudden they came alive! There was significantly more bass, the highs were smooth as silk and the imagining expanded massively!
I would love to know if anyone has seen any official information about how these speakers have been designed to be placed? Perhaps in a user manual? Has anyone else had a similar experience? Would be great to know if they have been designed to be against a wall or if its just the specific acoustics of my room and my other gear.
Whilst I’m much happier now with my speakers performance, I do think there is more to squeeze out of them. Common wisdom around the net is to treat the woofer surrounds with brake fluid. I must say that I am somewhat reluctant to go down that path. I worry that it may do long term harm.
I would also, be really interested in whether anyone has had success in treating their upper bass surrounds.
Lastly, has anyone has had their crossovers tested and/or recapped. Are they standing up still or have they started to deteriorate?
Looking forward to hearing other owners experiences.
All speakers require a minimum of 50 to 100 hours of "Robust" operation before you can expect reasonable performance.
Age means nothing.
Speakers work like muscles, When you stop using them they Atrophie as in goes back to an Unbroken-In like new state.
Not sure why this concept is so foreign, It's obvious and is the only theory that explains what everyone has experienced at one time or another.
Sorry to bring up such a painful subject like Break-In...
Next topic... CD VS LP... LOL.
I don’t have enough knowledge or experience to argue one way or the other on this subject but what I can say is that the issue of the woofer surrounds hardening with age on diatone speakers is a well known phenomenon. It would seem logical that the movement from using them would assist in loosening and softening them. Having bought the speakers from a commercial store, I have no idea of their specific usage history. All I can say is that they are in pretty much mint condition.
Start a thread on how to soften surrounds. You can't be the only one with this....Beautiful speakers from a classic time....
Over the last week or so, Ive made some MASSIVE improvements.
1st, Ive tried some very heavy concrete blocks for stands. Each speaker is now sitting on 2 concrete blocks wrapped in towels to protect the speakers and carpet and to try to absorb some vibrations. This certainly helped. After listening to them for a while on the floor, it became obvious that the bass was quite boomy. Putting them on the blocks got rid of that. This is just for testing for now, but has given me some good ideas for a permanent solution. I still felt though, that overall they were quite light on for bass.
I started to realise that bass really only kicked in when there was lots of very low bass. When the music didn’t go that low, it felt very thin. It was then that I turned my attention to the mid-bass drivers. I realised they were constructed in much the same as the woofers and used the same materials. This meant the surrounds had suffered from the usual Diatone hardening. I treated them with some Dot-4, massaging it in firmly with a queue tip. After a few minutes on each, they softened significantly.
The difference in sound now is just amazing. Bass is full deep and smooth as silk. It has also really filled out the higher frequencies, they are smooth and detailed with none of the harshness i had been experiencing. Imaging is amazing
With these issues now fully resolved, I have achieved my audio nirvana like I never would have thought possible. These Diatones are stunning!
Thanks for the impressions, I just caught on to these speakers and became intrigued. You were right to back these into the wall, all speakers of that era were designed to be right against the wall (at least all the ones I've seen growing up were). I looked at the anechoic response of the the DS-5000 and was also surprised to see that the bass response is like that of a mini monitor, which suggests it depends heavily on room gain. I'm assuming no toe in, but how's yours setup? Do the surrounds look servicable? Thanks.
The speakers are in great condition overall, including the surrounds. Just the hardening issue with the surrounds which is much better now having treated them. I did find one small split in the surround of one of the woofers. Don’t really know how significant an issue that might be. Is it something worth fixing?
As far as placement, thats right, no toe in. Mostly in an attempt to keep the whole cabinet close to the wall. I’m in the process of building some stands for them. They are simple particleboard boxes matched to the dimensions of the speaker bases. Height is the same as matching Diatone stands (275mm). I’m veneering them to try to match the speakers as closely as possible. The boxes will then be filled with sand to add plenty of weight. During all this process, the speakers have been moved around quite a bit for testing etc and have spent a bit of time just sitting on the floor. The take away for me has been that placement from the wall and height make a huge difference to bass response in particular. Right now they are on the floor close to the wall. Bass is full, but boomy. When I tried them on my stands (no sand)near to the wall but with perhaps 10cm gap, bass response was less(but still decent), and much tighter. Looking forward to seeing how they go on the completed stands in a few days.
Have you checked the surrounds on both the woofers and the mid-bass drivers on the DS-5000’s? I have a feeling the mid bass often gets neglected, but these make a huge difference.
Oh, one last thing. My DS-3000’s were fitted with very nice binding posts to take banana plugs, but that meant that the cables protrude quite a bit from the back of the speakers, limiting how close they can be placed from the wall. I managed to pick up some cables with right angle banana plugs which allows me to place the speakers much closer. Would be interested to know how close to the wall we should be aiming for? I would imagine they shouldn’t be actually touching?
I don't have much to offer regarding the sound of these but I just wanted to mention I've seen DS3000s in Hifido many times myself. I thought that store was going out of business (the one near Akihabara is where I saw them,) but I hope they're still open. Enjoy!
They are still in business as of today. Just purchased a pair of Diatone DS-2000s from HiFiDo last week and received them today.
I’m sure you’ll love the 2000’s!
I have been meaning to update this thread with my on going experience with these Diatones.
They really sounding amazing in my system now! Things I’ve learned along the way that have really made a difference with them:
*Placement close to the wall makes a massive difference. I even had some custom cables made with right angle banana connectors so I could get them close as possible.
* Heavy solid stands. I made my own which are basically particle board boxes with internal bracing and then filled with dry sand. I then veneered them to match as close as I could to the cabinets. I used some plastic/rubber feet that came with some Wharfdale Linton speakers I bought to sit speakers on top of the stands. I figured Diatone knew something when they designed the original stands so I made my stands the same height.
*Make sure the Bass and mid bass surrounds stay soft. I’ve had to re-treat those once already. They did start to re-harden and were starting to sound a bit thin. Quick treatment and they were singing again! Still weighing up the possibility of having the surrounds replaced at some point.
All this has added up to a massive difference compared to what I heard on day 1.
I have also recently upgraded my A-S3000 to a Yamaha C-5000/M-5000 combo and wow!, the Diatones sure are loving the upgrade! The bass really is coming forward now and it is smooth. The level of detail in the middle and top end is amazing, without a hint of harshness.
Obviously, your 2000s will not necessarily react in the same way in your system and in your room, but hopefully some of this will be a good starting point.
Enjoy
Hi everyone, I have traced and analyzed the crossover network diagram of the Diatone DS-3000. Since it's very hard to find this schematic online, I wanted to share it with fellow owners and vintage audio enthusiasts here.
Nice work! Always good to expand the knowledge base. Hopefully someone will find it useful at some point.
Just curious, was everything original in your crossovers, and what sort of condition was it in? Any new caps needed or anything?
53/500
Everything was original, but measurements revealed that the capacitors were degraded. Therefore, all the capacitors were replaced.
Trust me on this one: Copy all these images instead of relying on them to be visible in the thread for forever.
pssturges: If there are surrounds availlable from Japan, if it were me and I adored these speakers, I'd get them replaced.
DS-3000 plus Viscoloid speaker/Surround flexibility
・Dilute brake fluid with lower alcohol
・Dilution ratio is about 50/50
・Apply with a brush to the edge of the speaker.
・Be careful not to let the liquid come into contact with the painted surface as it will hurt the paint.
・A minimum of 6 hours is required for sufficient flexibility.
・Applying from the back of the speaker edge is also effective.
・Repeat if softening is not achieved after one application
If the Surround becomes too soft, apply liquid rubber.
