Difference between Infinity SM-82 and SM-85 speakers?
starcopy
I have a pair of the SM-82 speakers -- clearly marked as such on the plastic speaker terminals plate. But when I search for info I get four times as many hits for the Infinity SM-85 speakers than the 82s. There has to be a difference, right? Any 1990s Infinity speaker experts out there? Info appreciated. Thanks.
In a nutshell: Cosmetic differences.
The SM-80/82/85 tech sheet shows most all of what's relevant.
The fact that all three models use the same tech sheet makes it pretty clear the differences are'nt very significant.
The crossover schematic is the same for all three except a notation that the SM-80 differed slightly in one respect from the SM-82 & SM-85.
Yet the SM-82 crossover is listed as the correct replacement for the SM-80 crossover,so there's really no major difference there.
Tweeters all use the same replacement diaphragms too.
Most of the obvious differences are purely cosmetics related,different color printing & accents on the drivers,different vinyl for the cabs,grills and such.
So I would say the reason for more info on the SM-85 vs. the SM-80 & SM-82 is mostly just due to the SM-85 being a bit newer those others.
JM2¢ ~ FWIW
Bret P.
Your thinking makes a ton of sense, Bret. Thanks for your insight and for your effort. So, the tech sheet addresses both the 82 and 85 (plus 80). And I'm guessing that the SM 82 specs would probably be identical to the SM 85 specs? (My end game is to know what the specs are for my SM 82s.) Not sure why Infinity would make any changes (especially cosmetic) during those 1990s when the company seemed to be very cost conscious from what I've read. But it looks like the company was tinkering....
Oh, and I have an extra high-output Polycell tweet that needs a new diaphragm (I did all the testing, resoldering, etc on the old one but no joy. Probably the voice coil.) A new diaphragm would probably cost as much as a new tweeter.
Cheers
Specs -
Nominal Impedance: 8ohms.
Power Rating: 10-125 watts.
Efficiency: 98db @ 1 watt / 1 meter.
Crossover Frequency: 2800Hz.
Frequency Response: 42Hz-27kHz (72Hz-25kHz +/- 3db).
SM 82
Introduced in 1991.
Discontinued in 1994.
Original MSRP $438.00/pair
Oh.the difference I alluded to in the crossover is the SM-80 did'nt have a circuit breaker for the tweeter.
And both the SM-82 & SM-85 had added the circuit breaker.
Probably because of that seemingly frugal nature...
ie: It's cheaper to change cosmetics to keep a "fresh look" vs. completely redesigning the speaker as a whole.
I dunno,as I have no idea how much of that stuff is still available.
Sorry I cant help more on that...
And the tech sheet is available online,just look on Google images under >>> Infinity SM-82.
Anyhow HTH.
Bret P.
That helps immensely, Bret. I appreciate your time. Quick story: I was using the 82s without the "bad" tweeter physically connected while waiting for the donor tweeter to arrive. When I connected the replacement tweeter and turned on the stereo, the replacement tweeter did not immediately work. No sound. After a short moment of panic (10 seconds or so) the tweeter began to sing and all has been good since. That was probably the tweeter's circuit breaker doing its job.
An annoying thing about the single page “technical manual” for the 3 models (SM-80, SM-82, and SM-85) of Infinity speakers is that it lists both inductors as having an inductance of .6 millihenris, in spite of the fact that that the iron core inductor is over 4x the size of the ferrite core inductor. Even if by some miracle they have the same inductance, this “technical manual” doesn’t tell you which .6 millihenri inductor belongs to the woofer circuit and which belongs to the tweeter circuit. Further, the “technical manual” was revised long after the last SM-85 left the factory. Just sloppy documentation. I was considering upgrading these with air core inductors, but gave up after seeing their “technical manual”.
Ok, so the iron core inductor is only 3 times the size of the ferrite core inductor. I still don’t think that they have the same inductance.
