I always called it speaker wire, but now that I am older and have a somewhat respectable system or two, I am going to start refering to them as "Speaker Cables."![]()
If we look at the definitions offered by Websters, it looks like very few of us actually use cables. Because, as you said, in electrical applications, a cable requires that each wire be separately insulated.
Still, there's no way we're going to change the vernacular of this hobby. I think I still use speaker cables even though they are actually wires. (Although if i used them to pull my car out of the ditch, then I could call them cables)
By the definition of 'cable' you have posted, what usually goes to one channel of speaker is a cable consisting of a pair of insulated stranded wire conductors, each of which could also be called a cable, according to your posted definition of 'wire'. What a useful thread this is!If we look at the definitions offered by Websters, it looks like very few of us actually use cables. Because, as you said, in electrical applications, a cable requires that each wire be separately insulated.
I would say that most of use do use cables because a cable is a grouping of insulated wires. The wires within the cable may consist of either single conductor or multiple conductors uninsulated from each other.
Maybe we're saying the same thing and I just don't realize it?
Thats what I use...24AWG magnet wire on my SET![]()
Very close, but to add the key (and maybe assumed) distinction.
The distinction is that a cable contains two or more conductors insulated from each other whereas a wire is a single conductor, regardless if it contains one strand or many strands not insulated from each other.
~~~~~~~~~~~~~~~~~~~snip~~~~~~~~~~~~~~~
Cable:
3. Nautical
a. A heavy rope or chain for mooring or anchoring a ship.
Nautical: anchoring.
Anchor chain, for ships anchors, is anchor 'chain', there is 'no other word for it', and has nothing to do with wire or cable, except for the small cable which holds the pin to the anchor stopper so you don't lose it, causing the pin to become gear adrift.
rode /roʊd/ Show Spelled[rohd]
noun (in New England and E Canada)
a rope by which a boat is anchored.
Origin:
1625–35; origin uncertain
...and the countdown begins...
Christmas, of course! It's time for all good boys and girls to write Santa for more of that stuff that connects the little boxes to the big boxes.What you counting down to, Doug?
