John Parkey
Member
Greetings everyone, please point me to previous threads if this has already been covered. Looking on Ebay, you can find Telefunken 12AX7 tubes with the diamond, made in Germany, 2 letter date code for $30-50 and then what appears to be same tubes for close to $200 or more. Just a single tube. Can someone please tell me what the difference is and whether these less expensive tubes are junk or worth buying? It is all relative, so to help calibrate, I am looking for a single tube for a Bellari 130 phono pre amp and also a matched pair for a Jolida FX III tube DAC. I substituted a Slovak tube into the Bellari and there was a noticeable improvement over the inexpensive stock chinese tube. Using a variety of vintage amps and a Pioneer PL 530 with Ortofon Red cartridge, KEF 103/4 speakers. I have used the inexpensive chinese tubes, Electro Harmon, and RCA Black Top tubes in the DAC, in that order, and have noticed an improvement with each change. I am using the external DAC with a Classe CP 47.5 pre amp and Bel Canto eVo 4 gen 2, bridged to 2 channels, and Infinity Kappa 8.0 speakers. Thank you for your help with this matter. --John
