difference between Yamaha AX-500 and AX-530
_mana
Hello, could anybody tell me what is the main difference between Yamaha AX-500 and AX-530?
They both looks the same, the weight is almost the same and technical data look the same too....
There is even AX-630, which is almost the same, but there is added Yamaha YST slot.
Thanx in advance.
Michal
Yamaha AX-530
Specifications​
Power output: 85 watts per channel into 8Ω (stereo)
Frequency response: 20Hz to 20kHz
Total harmonic distortion: 0.01%
Damping factor: 80
Input sensitivity: 0.16mV (MC), 2.5mV (MM), 150mV (line)
Signal to noise ratio: 76dB (MC), 92dB (MM), 102dB (line)
Channel separation: 60dB (MM), 60dB (line)
Output: 150mV (line)
Speaker load impedance: 6Ω (minimum)
Dimensions: 435 x 141 x 332mm
Weight: 7.8kg
Yamaha AX-500
Specifications​
Damping factor: 50
Signal to noise ratio: 73dB (MC), 90dB (MM), 100dB (line)
Channel separation: 50dB (MM), 50dB (line)
Speaker load impedance: 8Ω (minimum)
Dimensions: 435 x 139 x 332mm
Weight: 7.7kg
Yamaha AX-530
Specifications​
Damping factor: 80
Weight: 7.8kg
Yamaha AX-500
Specifications​
Damping factor: 50
Yamaha AX-530
Specifications​
Damping factor: 80
Weight: 7.8kg
Yamaha AX-500
Specifications​
Damping factor: 50
Weight: 7.7kg
Weight: 7.7kg
thank you very much!!! so only little differrences. AX-530 seems to be an upgrade, so maybe even better.
