I've got 7B's with peerless tweeters with the grill mounted badges. I had a set of 7A's with peerless tweeters. The obvious difference was in the shape/depth of the passive radiator and maybe the weight in the center of the passive radiator was heavier in the 7B (for a different resonance frequency perhaps). The cone of the passive radiator looked deeper on the 7A, but that might have been an illusion because of the smaller weight.
There's nothing different about them having been purchased in Japan, they are what the early 7A's looked like. Yours are not the very first though, they had a plain paper passive radiator verses the doped paper in yours.
Indeed, my 7As look just like that. Mine, which I believe to be pretty early 7A (but I don't have serial numbers handy) have two fuses per loudspeaker on the back panel: tweeter fuse and system fuse. I believe later versions had only one.
I found a difference. The passive radiator has a deeper cone on the 7A's. The weighted center is smaller on the 7A's too. I'll know more when I open them up to see if the crossovers are the same.
