cpt_paranoia
Addicted Member
That is correct; higher sampling rate means Fs/2 is way above the audio band, so we don't need to use very steep ('brick wall') imaging/reconstruction filters to remove the sinc images created by the zero order hold that a DAC creates. These more relaxed filters can have more linear phase and amplitude response in the audio passband.The main reason for higher sampling rates is to keep digital artifacts out of range of the human ear with out using very destructive filters that can influence the sound.
The orignal Philips CD player used a 14-bit TDA1540 DAC with a 4x upsampler, allowing them to achieve near 16-bit performance. But the side effect was a simpler filter at 88.2kHz. Sony opted for a 16-bit DAC, sampling at 44.1kHz, so required a high order imaging filter to meet the 22.05kHz stop band response (the filter actually started rolling off just above 20kHz.
This appears to be a somewhat confused justification. Manipulation during production ideally needs more precision (i.e. bits) to allow multiple track mixing, etc, without losing detail. Only at the final mastering stage do you apply a truncation filter (to add dither), and truncate to the output resolution (e.g 16 bits for CD). Higher sampling rates don't really help if you only have to digitally filter to remove any content above the output Fs/2 (which you must, if you are not to have aliasing artefacts, which you really don't want).So if your source has been overly manipulated in the studio or during the original performance you definitely want those higher sampling rates. More manipulation requires higher sampling rates.
Actually, it's not about 'detail' today; the worst 'engineering' errors are 'loudness wars', either hard limiting, or soft limiting, intended to make their recordings sound 'louder' on radio, and to work 'better' with ear buds. It's about the mixing and mastering; it always has been. There has always been, and still is good mastering around (e.g Steve Wilson's work on remastering). It's just that morons in record companies seem intent on actively destroying music, even old recordings, when creating streaming masters, or remastering for CD. These tricks (especially hard limiting) cannot be done on vinyl, because the stylus would not stay in the groove.recording engineers playing with a new toy that allowed them to make overly detailed recordings and so it goes today. Its all about the details and forget what the ctual perforance really sounds like.
AgreedI guess it all depends on the quality of the source.
Agreed: see my comments about loudness wars and mastering.So I have said in the past its not the medium we choose its the people who use the medium to capture the sound that we choose to enjoy. All can be very acceptable or inspiring but in the wrong hands sound like ****. Excrement.
The giveaway that the digital medium itself is not the problem is when people needledrop their vinyl, and cannot then distinguish the digital playback of that needledrop from the vinyl playback; digital has the capability to perfectly reconstruct the vinyl recording (which, in most cases, since the mid-80s, was mastered and created using digital methods).
