From 3 years ago
http://www.audiokarma.org/forums/attachment.php?attachmentid=260423&d=1299275930
Test Equipment:
Toshiba SR-F770 DD Turntable w/ Signet TK7EA Cartridge
100 gram x .01 g Mini-CD Stealth Scale
Levolution 12" Spirit Level
Starrett 6" Combination Square (height gauge)
George Shearing, The Shearing Touch LP (Capitol ST-1472)
36 RIAA Equalized Ceramic Poker Chips (blue and white randomized to discourage standing waves and/or 3rd order harmonics)
1 Andrew Jackson Family Portrait for Control
Test Setup:
Cowboy Junkies on the stereo. TT leveled. Arm leveled. Platter removed after 'normal' play height measurement taken using The Shearing Touch LP which seemed a nice smooth, calm choice.
Test Procedure:
In all 50 measurements were taken. 10 for control and 10 at each of 4 heights as per the table below. The arm would not go any lower or another set of measurements would have been captured. The scale was shut off and then powered up to self zero for each measurement. The stylus contact location on the scale remained very close for all measurements. The tracking force was set to 1.25 g for measurement 1 at +0.63 inches. The 0.26 inch above normal measurement corresponds to this scale on this turntable with the rubber matt removed.
In Conclusion:
As the arm was lowered the measured tracking force followed.
The rate of change in measured tracking force seems to be fairly linear.
The deviation of the control measurements exceeded the tracking force measurements.
The maximum deviation for all 40 measurements was 0.11 g. The control deviation was 0.04 g. Therefore the maximum deviation of measured tracking force can reasonably be said to be .5(0.11 - 0.04) = 0.04 g
Opinion:
Until I get an expensive SoundSmith strain gauge or Ortofon SPU cartridge my $15 digital scale should do just fine.
I still don't understand why the measurements follow the arm. Intuition tells me this is backwards. As the angle is increased the pivot would seem to bear more of the force, so the force at the stylus should decrease?
Just For Sh!ts and Giggles:
I took a few measurements at the +0.63 inch elevation with the same 9 chips on the scale. The weight of chips is 76 grams which puts the measurement much closer to midrange for the scale. The control bill still weighed in a 0.98 grams, but the TF consistently measured 1.32 grams or 0.06 g higher than the average at that height.
Still probably negligible.
