Carraway
Well-Known Member
I thought I'd start a thread for people's experiences, suggestions or questions on digitizing vinyl.
Thanks to this forum and the DeOxit guide, I resurrected my pre-amp with a phono stage and with it, my turntable. Then, filled with the energy of turkey and fixings, I started digging up my vinyl, found a lot of things I'd missed and decided to try digitizing a few albums. I've been feeling my way through it, but here's my process, as wrong as it may be.
Turntable -> phono input on preamp.
Preamp tape 2 monitor out (tape 1 out is still had issues)-> RCA to miniplug -> Macbook running Audacity. (Audio port changed to input).
Audacity sample rate is at 96K, but the files have been huge. I'll set it to 48K for the next one.
I record a full album into a single Audacity track. Afterwards I copy each piece into its own Audacity track, cutting some of the beginning/end space. (I remembered to leave some end space so the digital version isn't jammed together).
I then export each track in AIFF format. I tried experimenting with some others, but they need additional downloads, including MP3s. So I've used AIFFs for now.
The next step is I adding files to iTunes (and add a photo of the cover). They worked well on my laptop, but I received a "Nope" notice when trying to put them on my phone. So I reset my iTunes' import settings from Apple lossless to Mp3 at 320Kbps. I then convert the files in iTunes (so each album has both an AIFF and MP3 file). The MP3s will play on my phone, so I was able to do some errands today while listening to an album I haven't heard in a long time.
I'll probably need to use a separate hard drive if I want to save the Audacity project files; each LP file is over a gigabyte at 96K.
So, any ideas?
So, any ideas?
