Hey guys,
I'm trying to restore a vintage PA tube amp (2 el34, 4 ecc84)
and I've built a dim bulb tester in order to test it.
Let me say in advance that my knowledge in electronics is far from being good. However I'm making sure to use saftey measures for my own safety.
the tubes are out. I've connected the dim bulb and the amp to the socket, both "standby" and "power" are on "0". I've switched "power" on and the amp starts making "working" sound (hum) but the bulb won't light. then I switch the "standby", and the bulb light bright and dim quickly (like it should I guess)
My question is, Why won't it light when using the "power" switch, and does it mean I have a problem?
Thanks everyone.
*I use a 75w light bulb for a 50w amp, and I've connected it to a 4ohm speaker rated 30w (I know that it's far from being great but I've read that It's possible just for the test)
Thanks everyone.
