I just built a dim bulb tester, I'm pretty sure I hooked everything up correctly, my question is how do I test it, without a shorted piece of equipment? I'm using a 60 w bulb, it does not burn brightly when somthing is pluged in, that is good, however it does not dim which it should do without a short! When I turn on the tester, with the amp luged in, the amp comes on, just no dimming of the test lamp. Thanks for your help!
