c.coyle
Fighting the Dunning-Kruger effect.
Fixing up a friend's Marantz 2252B. I pulled and tested the output transistors, then re-installed them with fresh mica and grease. Before pulling them, I had carefully noted their position - NPN PNP PNP NPN - and even made a diagram on my bench. Embarrassingly, I completely forgot the diagram and put them back in NPN PNP NPN PNP.
I came this close to saying "bleep it, just plug into the wall", but a little voice said "do it right." So, I plugged into the DBT and that sucker stayed bright as the sun, and no relay click. Figured it out, switched them around, and all is OK. The diagram was right under my nose the whole time.
God protects infants and idiots.
