harleyrider
I just finished my dim bulb tester last night . Wanting to see how it worked , i grabbed a old dvd /cd player that powered up but would not play so i wasnt worried about killing it . Plugged it it in and powered it up , light got bright then went dim approx 30 seconds later then went out . Is this correct for a good working unit ? Not knowing exactly how to use my tester i just through the on /off switch of the tester and got a serious POP from the dvd/cd player . Im sure its toast but i dont care about that . It was simply used for this 1st test of the tester. 60 watt bulb is all i had laying around , im thinking maybe it was to large for the dvd/cd player used. I have searched here on this topic , just havent found anything saying NOT what to do . Any inputs on what not to do when using a dim bulb tester ? Thanks Chris
