bimasta
Addicted Member
Is this a standard 5-Pin DIN 180° socket? It's in the base of a tonearm (Odyssey RPG2). I need the matching male plug, as I have to make a new cable.
Most tonearms now use a smaller, special DIN designed for tonearms, but the Odyssey uses this one, and a normal tonearm cable doesn't make a good connection. The pins are smaller, spacing a bit different, and contact is intermittent. So if this photo is the standard 180° DIN, making a cable will be easy. If not, I have to rethink everything.
Can you help ID it? Sorry for the poor focus, but I think it's clear enough to see what it is.
Thanks in advance!
Bimasta
Thanks in advance!
Bimasta
