Discwasher D4 or D3 forumla ?
Duckland23
Member
Hey guys
I was wondering if anyone knew I difference from D3 and D4 cleaning fluid .
I have big giant bottle of D4 fluid and I am using it too clean my dirty record store stuff I'm buying to get my vinyl back .
My record doctor v which I bought for 125 off faceFace market place is great .
I got a half a bottle of the record doctor fluid and I have a small amount left now .
I have a big giant bottle of D4 which I got from eBay .
I notice that it flows good on the vinyl records well .
I did like the record doctor stuff too .
I see you can buy many types of fluid .
I don't think I'll do the diy stuff ,I won't use isproplol aloholo on my records I've heard alocholo back for vinyl it breaks it down .
I've heard of this company phoniex which sells a gallon of cleaner pre mixed for 35 bucks .
I've seen many but I want one for dirty records I don't want that dirt on my stylus .
So let's hear what u guys use and how I can clean them up good and not breaking the bank .
While not optimum, I clean records in the sink with a soft cloth and Blue Dawn. My experience has been nothing but good, providing I rinse really well. Even new records that had surface noise have benefited.
Cleaning records is a controversial subject with not a lot of agreement. The sink method seems to also remove the static electricity that is a big problem in my house. It is a little burdensome to do every record every play, so once a record has been thoroughly cleaned it most likely will not ever need it again. The formula 427 posted will be just fine on a Discwasher brush for everyday use.
Power-washer gets all the stuff deep in the grooves out. Removes labels too.
4-2-7's DIY fluid is the same I use. Works great and alcohol doesn't damage LPs, but too much and wow increases along with pitch instability.:beerchug:
Your choice
You heard wrong
Distilled water
IP Alcohol 90%
Drop or two of dish soap
Drop of Photo Flow
Yes but you have buy all this stuff ,in the end I'm better off buying pre made cleaning fluid .
I know you can't fix a record that's scratched too hell from not taking care of it .
I have damaged a record from alcohol ,it made the vinyl look dull .
But did clean it up .
D4 is better than D3...later version and all.
FYI, Pfanstiehl bought the formula for the D4, with only a change to the anti microbial additive. Still available. IIRC
You can make gallons the way I do it far cheaper than buying some cleaner in a pint bottle. Many of use have been doing this a long time and doing the best economically way.
I find that very hard to believe using IP alcohol, even denatured alcohol or lacquer thinner would not do anything visibly to the record.
BTW 99% of any pre-made cleaner you can find will have alcohol in it.
Armor All will make that dull record shine again. Unlike CDs, Armor All doesn't make tracking better. :crazy:
Hi I bought some concentrated cleaner called Groovinator I have been using it for about two years with very good results the ratio is 32 to 1 so it will last a long time
Great I bought some record doctor RXLp for 20 bucks from audio advicer in Michigan .
Makes one gallon good enough for me .
Just spill the small bottle in a gallon of distlled water and let set for 15 minutes it's ready too go .
My D4 which is a older bottle not cutting it anymore I think the surfactant is gone in the bottle .
I've seen groovinator on eBay I though about getting a bottle of that too . But I liked the record doctor RXLp fluid it seem too wet the record right too .
I also heard good reviews about TM-8 and audio intillintel 6 one step .
Yes, Spin Clean's work well but the fluid is pricey and there's really not much to it. Certainly no alcohol since it can be used with 78's.
1/8 teaspoon of Alum powder (flocculant) dissolved in the Spin Clean's trough of distilled water.
6, 7 or 8 drops of Photo Flo (surfactant) dropped onto the brushes, just like Spin Clean directs one do with their fluid.
And it does exactly the same job. No alcohol, no Jet Dry, no dish soap - just two components plus the water.
The most expensive ingredient (about $20 for 16 oz) is Photo Flo and a 16 oz bottle will last hundreds of sessions with a Spin Clean. A small can of Alum powder, for dozens of sessions, is about $4 at a supermarket and distilled water is however much distilled water is - $2 per gallon?
The last time I saw a 16oz bottle of Spin Clean fluid in a local record store it had gone up to $40 and the last time I bought any it was $19.99, same shop, and the water was extra.
There is no longer any reason or need for me to buy commercially made record cleaning solution ever again. Not while I'm using a Spin Clean anyway.
That's just too much fussing for me.
Add this add that .
It's way easier too just buy fluid premixed or a concentrate fluid you mix with water too .
If that works for u go fo it
I use:
Distilled water
Triton X-10 (Tergitol)
99.9% Isopropyl Alcohol
Behentrimonium (a quaternary compound, which helps with static)
I mix it myself, and I've never been bothered by the couple minutes it takes to prepare a batch. I have enough of the Tergitol and quat to essentially have a lifetime supply, and this solution works great, so I will spend the savings on more records :banana:.
Yes and I'm really not interested in investing all that money in that home brew .
I'll pay for the pre mixed stuff .
It's engineer for records ,diy isnt engineer it's just some avraave job blow mix on a budget stuff .
I'll take my trust in record doctor and audio intelligent .
Or Last
