FairhopeJon
Just purchased a Zenith Y960 in good working condition. This is my second solid state console I’ve recently purchased. My first was a 1965 Voice of Music with record, am/fm and R2R. I love the Zenith purely because of the mid century modern styling and analog display, however, the VOM sounds much better. Nice clean lows and pretty decent mids and highs. My goal is to keep the Zenith and either use the parts from the VOM or simply sell it as I don’t have room for both. The Zenith console has two 15” woofers and two horn speakers. I can adjust the balance and get pretty nice highs but there is a muffled, distorted bass sound that I can’t get rid of. I used DeoxIT on all of the connections, as most of them had a yellowish oxidation. Not sure what to do next. After a bit of research, I’m thinking it might have bad capacitors (although I’m not even certain what those are). If so, does it make any sense to try and swap the solid state amps or just replace the capacitors?
Or am I way off? I know very little about this, so patience is appreciated.
I’ve attached some pictures of the Zenith. Can also upload pics of the VOM if that helps.
Thanks in Advance!
John B
Learn something new everyday!
