tomlinmgt
Lunatic Member
Michael, do you know or can you point me to the answer of "what-if" the "diffuser" is made 72" tall instead of 48"? I'd really like to make a set of these for my Maggies (MG-2.5's) and it seems like they'd be more effective if they were at least as tall as the speakers.
:scratch2:
I have run across this info, but don't recall where (buried in one of the many eye-glazing technical discussions about diffusion over at gearslutz, I imagine).
Anyway, unless you plan on standing up to do all your listening (and you're at or over six feet tall) it would be overkill. True, if you position a four foot tall diffusion device a foot off the floor that leaves a foot on top and a foot on bottom that, for a six foot panel, isn't "covered" by the device. But in your seated listening position your ears are likely about three feet off the floor and that puts your head almost in the center of a diffusion zone ....which is right where you want it to be as this is conducive to recreating a realistic sound stage. Adding more vertical range to the horizontal diffusion pattern (assuming your talking a 1D diffuser) really wouldn't be necessary unless your ears are situated toward the top of the panel when you listen. And even if that were the case, you could just move the diffusion device up to the location that put your ears along the device's horizontal center line. Make sense?
