In the past, I've always configured my amplifier test rig using alligator clips, but I figured I should create a hardwired setup. I want to be able to switch the DBT and variac in and out as necessary; when they are bypassed, they should be fully deenergized and entirely removed from the circuit. I also want to have a bypass switch for the panel ammeter in case the anticipated current draw exceeds its limits. The input will have a fuse holder to prevent excessive current in case of a short with the DBT switched out. I think I will use a G9.5 lamp holder instead of a normal E26 socket because I've discovered that very high wattage incandescent lamps (300w+) can be had for cheap in G9.5 form. Also, the G9.5 bulbs are far smaller than equivalent wattage E26. I have a few amps in my backlog that love current, so large wattages are necessary for the DBT to be useful.
I drew up a quick schematic in MS Paint and would appreciate any feedback on this circuit or the project overall. Once I've gotten started, I'll post some pictures. The panel ammeter, panel voltmeter, and variac are already en route. I plan on using an MDF panel for ease of drilling cutouts with the holesaw.
When choosing parts from Mouser, I realized that a 15 amp 120v 4PDT switch is somewhat exotic (and costs about $40), so I might replace that with two more DPDT.
