BillR mastering
First system, 1972
Given that some of the better record cleaners are in the 4K price range, over the winter, I am going to attempt to build something that will do a good job, as close to the 4K type units as possible.
I am going to need the vacuum pump, fluid container and exit container, suitable arm for vac and assembly of the suction arm. Of course, I need to build the box and stand to contain it all.
What I have so far is a Pioneer PL 518 turntable that will be used as the platter/ parts table. Its motor should provide sufficient torque.
Anyone ever tried this? Any parts tips/links?
TIA
TIA
You need a serious motor, slow speed, high torque... ice cream makers are very popular. You'll also need to use some kind of clamp for the LP, or the vac will just hold it still while the platter turns underneath.
