Yep, a blow by blow, step by step would be great, including a parts list. Maybe even make it a sticky if it gets people in the end with a good RCM.
Hello
Question for anyone who has built a RCM that uses an ice cream maker machine motor what RPM does yours turn at? The one I have looks to be spinning at around 45 RPM.
Is this too fast?
Also for anyone that used the VPI wand what is the dimension from the center of the mounting to the end of the wand. Or how far away from the platter is the base?
What I am after is I want to try and make my own wand but if it does not work to my satisfaction I would like to be able to convert it to the VPI wand
so I need to be in the ball park of where I mount it.
Hello
I use a ice cream maker motor on mine and it turns about 25 rpm. As long as it does'nt fling the cleaner off as its spinning, I don't believe that speed would hurt anything.
I use a ice cream maker motor on mine and it turns about 25 rpm. As long as it does'nt fling the cleaner off as its spinning, I don't believe that speed would hurt anything.Hello
My first DIY RCM used an ice cream maker motor. It spun at about 38RPM - too fast for my liking. (I just ran it for 60 seconds and counted the revolutions.) As it was an AC gear-reduction motor, reducing the voltage to slow it down didn't really work. I ended up getting a small DC gear-reduction motor on eBay for around $10. I think it was rated for something like 18RPM at 12vdc. (VPI's motor spins at 18RPM.) I use it at 5-6V for around 8-9 RPM and I like the results much better.
I can take a photo of mine to indicate mounting distance.
Platter rotation seems to be between 33 and 45rpm, but I haven't timed it. It doesn't seem to be a problem.Hello
Is this to fast?
Thanks that would be very helpful
