Really nice looking amp, as far as the pop, it's perfectly normal, to avoid this you would have to install a relay circuit.
To keep everything simple I didn't bother with this, but do what I do and turn on the preamp first and the power amp last. When powering down turn off the power amp first and preamp last and there will be no problems.
If you want to measure DC offset, set your DMM to at least 200mv's. Put the positive lead on the right or left positive output of the preamp and the negative lead to the negative output. It should read zero if you have the output caps installed.
Before connecting any of my projects to other gear I always check for DC offset at the outputs and inputs just to make sure I don't have an "oops" and destroy something.
