Tube Radio
I built my DIY speakers about two years ago and at the time I used a 6db/octave passive crossover with them. I recently built a small pair of bookshelf speakers (cabinets from a pair of auvio 6.5" two way bookshelf speakers with better speakers + crossover installed) and used a 12db/octave crossover with them. They sound much better than my DIY home stereo speakers so I'm gonna re-do the crossovers to be 12 db/octave which should get me better sound. I am keeping the l-pads in place as I have no clue what the efficiency of the midrange compression driver is with the horn lens I have installed on it. Now I could figure out an L-pad circuit using two resistors for the tweeter, but I like to be able to adjust the midrange drivers and tweeters to the amp I am using which right now is a Scott LK-72A. Now OTOH if I had something to measure the midrange driver's efficiency I would do away with the variable L-pads altogether and go with a fixed L-pad circuit. Maybe y'all can help.
I am using these components
Aurum Cantus G2Si Ribbon Tweeter SPL 96.0 DB 1W/1m with 2 ohm resistor in series to provide for 8 ohms impedance.
Eminence PSD:2002S-8 1" Titanium Driver 8 Ohm Sensitivity: 105 dB (1W @ 1m on axis horn) connected to a Dayton H08RW 8" Round Waveguide.
Eminence Delta Pro-12A 12" driver SPL: 99.2 dB 1W/1m
Looks like I don't need an L-pad circuit on the tweeters and apparently would appear I need to get tweeters with a higher output.
