cykotic
I am pretty new to this but am planning on building a set of vintage JBL C35 bass reflex speaker cabinets but will be using newer JBL Components. Specifically, JBL 2226H 15" woofers, JBL 2426H/J HF compression drivers with JBL 2370A horns and JBL 3120A crossovers, crossing over at 1250 Hz . I will be pushing these speakers with a recently restored Sansui 9090DB at 8 Ohms. The 3120A JBL crossovers call for a LF of 8 ohms and a HF of 16 ohms. My question is this...will I run into a problem using an 8 Ohm HF compression driver which matches my receiver output, that being the 2426H, or would it be better to use the 16 Ohm compression driver, the 2426J, which the crossover calls for? Or does it even matter? Any help would be appreciated as I can't really find anything addressing this particular issue via Google.
Thanks much,
-Cykotic
Thanks much,
-Cykotic
