DIY Wall Mount Turntable Shelf
WilCruiser
I've had trouble with Turntable Isolation (bouncy floor joists) and after considering a few options I decided a wall mount shelf would work best for me. Didn't want to drop $150 to 200 so I read a few different ideas on construction and came up with this which borrows a bit from a few different sources. Thought some of you might be interested.
Started with a pair 15" shelf brackets from Lowes. They're actually very solid despite first visual impression. I then took a 3/4" piece of 7 ply thin veneer plywood and cut it to 19" X 19" and built a little box around the edge of it with some 1/2" X 3" poplar. Painted both to match the shelves in the listening room (brackets were originally white):
After mounting it on the wall (using some boards horizontally to make contact with studs - but allowing me to mount without being constrained by the location of the studs) I filled it with walnut blasting media. Not for any performance reasons, just that I had it and it was free. Very much like sand:
I leveled that off and dropped an 18" x 18" slab of travertine tile in the middle...
...keeping about 1/2" all the way around to allow the walnut (sand) to isolate:
Dropped the Thorens on it and it's made a HUGE difference. All for less than $50!
With it painted it fits in nicely too:
A very simple project with huge returns on the quality of playback. I highly recommend it if you don't already have effective isolation in your setup.
Nice looking work WilCruiser! That sand, the travertine, and the thorens make a gorgeous color combo
Now take it all down to paint the wood on the wall to match the wall colour and increase WAF by a factor of 10. ;)
Looks awesome! :thmbsp:
Nice I think this is the first wall shelf I have seen that ended up incorperated into an existing stand/rack. Very well done.
Thanks all. I actually had to put some spacers in to enable the rear supports for the equipment stand to criss-cross behind the shelf without touching it (don't want those vibes!)
Couldn't find the remaining paint from the wall or I would've painted the boards too. Once the stand is loaded you can't see the boards anywho. That'll be a project for another day. Didn't want to wait to hear the results! :D
I hung my AR turntable with three wires from the wall in the 60's. The wires were joined together under the table and were connected together with a screw into the wall. It isolated the table from all floor vibrations like wlking or jumping.
Lowe's is the audiophiles friend. My entire system is set up on industrial racks and shelving. And for the first time in my life I am in a house that sits on a concrete slab. Nirvana. Bouncy floors lead to madness.
Now, this is what the Internet is really for! Great project, WilCruiser. Very well-written and well-illustrated posting too.
Awesome!
I just did the same thing (sorta).
I have plaster walls, so the use of butterfly anchors was needed. I just used two 20x20" plywood (walnut veneer) bolted together and mount on brackets. no sand.
The difference is amazing! I can walk around/minor listening teaks/tap my feet/and even jump up and down!
Yours does look waaaay better then mine btw!
Great creativity! Very nice job! It's nice to see someone thinking outside the box to save some dough.
Looks good to me- Those shelf brackets are sold everywhere,and they are hefty.The main thing is to anchor them in to solid wood with the right hardware.They are what this old shipfitter would build if they weren't already premade-I have 6 or 8 in use around the house now.
On my main equipment wall,I haven't put up some sheetrock yet,so I am able to beef up the wall.It's a good time to add some studs.And I can bore holes and wire from the back,while standing on the basement stairs.
Those brackets are pretty strong,compact,and you can get other equipment and racks to fit under them pretty easy.:thmbsp:Good job!
Great looking wall mount, where did you find the brackets? They are exactly what I have been looking for!
