Nice Job.
I have a nice set of very early dlk 1 1/2's (#578;580)-birchwood cabs, Alnico green basket woofers and CTS ring tweeters.
Bass is outstanding, and rocks easily with 50-75 wpc.
IMHO any of the DLK's that use this tweeter, this was clearly it's weakness. They had a tendency to beam very badly, with the very narrow sweet spot. Sometimes smooth, but lacking any real detail. Horrible IMHO
In fact DLK made a limited edition 1 1/2 that used the Peerless plate style tweeter.
http://w.mawebcenters.com/midwestspeaker/ecommerce/mw-audio-mt-4115-tweeter.html
They also used this style in a few other models. Very nice unit.
The best tweeter I have found, that will closely fit the 3" cutout, and come close to filling the 4.21 " out side diameter is this Vifia tweeter (4 and 8 ohm).
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=264-1026
And is a budget champ.
This tweeter will completley out perform the CTS tweeter in every category except nostalgia. Very smooth with good dispertion. Very detailed as well-especially for the price.
You will need drill 4 new holes, and use some Hurricane nuts, or Menicus also make some nice alternatives that will use the stock screws.
http://meniscusaudio.com/8x1-ss-ms-p-382.html
Midwest speaker alos sells replacment grill foam-which most old stuff is dry rotted.
http://w.mawebcenters.com/midwestsp...th-foam/mf-1-2-foam-speaker-grille-cover.html
They also benefir from some added stuffing as well (fiberglass works very well).
In the case of the DLK 1/2's (which are easy to find around here in excellent shape for under $100) pr-this becomes a great speaker, and in another league with a good tweeter.
A recap is also a must-but for under $150 dollars, you will end up with a speaker that will have huge bass, clear highs, and work well with modest power.
The upgrade is also completly reversable (not with the plate), and wouldn't be noticed.
I wouldn't get too nostalgic about those CTS tweeters, you don't know what your missing with the tweeter upgrade-hell DLK finally realized it when technology advanced. and installed soft domes.
The advantage of those rings at the time were they were cheap, could go down fairly low for a 2way, and where fairly smooth in there response, comparded to the alternatives at the time.
I would still like to find a nice cheap small Heil and crossover from a ESS PS6/PS8 and install it in the DLK 1 1/2's-this would be a killer speaker for sure.
The woofers can take alot of abuse-been to plenty of parties back in the day-and those speakers wouldn't die (except for the tweeters-and caps at times)-never saw a rubber surround woofer blow up.
Again their advantage was great and realtively clean and warm bass, especially at louder volumes, solid cabinets, and a effective, but simple crossover. In the case of the older models, good looks as well.
Make sure if you choose another type of tweeter, that it can easily go to 1000hz, to work with the stock crossover.
