Gain and transition frequency
Transistor gain, gain code, Beta, hFE, current gain or amplification:
For applications in a circuit where a transistor is used to amplify the signal, it is critical to choose a transistor with roughly the same gain as the original device. Or your resulting unit won’t have as much gain as it did before.
How much a given transistor amplifies is referred to as gain or Beta of hFE. I am vastly over-simplifying here, but it makes sense to do so in a simple guide to finding replacement transistors. I'm not an E.E. so take the following as coming from an amateur or hobbyist. I'm sure a more-educated AK member will correct what I get wrong below soon.
hfe and hFE are two different h parameters of a given transistor.
hFE (uppercase 'FE') is signifies the DC gain, small signal DC current gain, or DC forward current ratio (all the same thing).
hfe (lowercase 'fe') signifies the small signal AC gain, small signal AC current gain, or AC forward current ratio (all the same thing).
Since there is wide variation in current gain levels, the exact numbers are mostly academic. Circuit designs are made to function across a range of hFE values rather than a specific hFE value. Designers know that manufacturing will end up with transistors of varying hFE.
For practical purposes:
The datasheet for any transistor device model should include a hFE rating. Many include sections like “hFE codes” or “gain codes” and list ranges of gain, e.g. 200 to 400, and assign “gain codes” or letters to these ranges.
Image of the gain code section of a datasheet
More info on hFE, gain, gain codes, etc.:
· What is the transistor hFE ranking? http://engineering.rohmsemiconducto...e/View/1/1/what-is-the-transistor-hfe-ranking
Transition frequency of fT:
Related to overall gain or hFE or Beta, the frequencies which a given device model will amplify are critical to match. This is transistion frequency or fT.
If you have an original who can amplify all the way up to 100 KHz, fT is 100 KHz, and you replace it with a device with a fT spec of only 10 KHz, then you’ll be not amplifying a large range of the signal you’re passing through that transistor and which you expect to hear, eventually, coming out your speakers.
There is a converse to this OK-to-be-under-but-cover-20Hz-to-20KHz point. If you replace a signal-amplifying transistor with one that amplifies much higher frequencies than the original, you may well be amplifying unwanted, higher-than-audio frequencies and making the rest of the amp work harder.
Ft in RF-signal circuits is extra-important. If your circuit, e.g. AM or FM IF or FM MPX circuit, is amplifying a RF-signal... but you choose a replacement transistor that does not amplify up to that frequency,. then you've cut off that all-important RF signal instead of amplifying it.
The capacitance of a transistor (cob which is covered inthe next post in thiis thread) has a direct effect on the fT.
Ø Tip: if you are considering replacing a transistor in an audio circuit with one that has a much-lower fT than the original, ask AK before you order.
- The 'f' or 'F' denotes a forward transfer characteristic, and the 'e' or 'E' indicates a common emitter configuration.
- The 'h' should be lowercase (and I'm not aware of any uppercase 'H' characteristic).
- When a transistor is used to amplify signals, hFE (or Beta) of a transistor measures its ability to amplify current. Higher values of hFE means more amplification of the input current.
- When biasing a transistor to set its DC operating conditions, knowing the hFE is crucial for determining the required base current for a given collector current.
- hfe / hFE varies between individual transistors of the same type due to manufacturing discrepancies, temperature and other operating conditions.
- This is the ratio of the DC collector current (Ic) to the DC base current (Ib) when vCE=0.
- A transistor with hFE of 100, for example, means for every 1mA of base current, the transistor permits 100mA of collector current.
- hfe is essentially the same as hFE (uppercase 'FE'), but measured with changing currents and voltages, as opposed to steady (DC) conditions.
- Use the hfe or hFE measurement that your tester measures. All the testers I've used show hFE (uppercase) or the current gain when vCE = 0
- "Matching" hfe between a schematic and the devices you have available is not about getting precisely same numbers. You are aiming for being near the range of the circuit design. If the schematic calls for a transistor with average gain of 600 and your nearest available transistor type is only 300-400, that's usually OK.
- "Matching" hfe between the actual device you'll use in one channel versus the same device in the other channel should be more precise.
