I've been experimenting with a pair of Heathkit AS-21s for about a month now - my first experience with horns. Unfortunately placement options are extremely limited in the room in which they are used. Aesthetically it is far more pleasing for the speakers to be placed flat against the wall but I noticed that when I was directly in front of either speaker, the sound improved dramatically. Toeing in each speaker 45 degrees resulted in a similar improvement at listening position - at a major expense of aesthetics.
The horns are Altec 811s and the manufacturer claims 90 degree dispersion but the listening position isn't much more than 45 degrees from center when the speakers are placed flat against the wall. I'd estimate the distance between the center from each speaker is around 13'.
Questions:
Is this behaviour typical of horns?
Is there any way of getting better sound without a major cost to aesthetics?
Does anybody make casters that would not have to be drilled into the speaker legs?
Questions:
