I learned long ago which metrics correlate to what we hear - and those like THD that do not. Dave O'Brien helped confirm that for me.I have finally figured your angle.
YMMV.
Thanks for getting us back on trackI have a big isolation transformer that sits between the wall and my stuff. Not the faintest clue if it actually does anything audibly, but it serves as both a power strip and an extension cord. I do notice the power transformers on the tube amps hum slightly less with that in place, so maybe its removing a bit of residual DC on the line.
Despite my general distaste for your contributions to this thread (and those that are combative on the opposing side) because you all but seem to be calling the other side ‘idiots’, I completely agree w this statement. THD is kind of a joke. The best sounding gear I’ve heard had some of the worst numbers. Could just be my bad ears or it could be that the numbers are always so small that matters little, or that distortion we readily hear is at a frequency extremes right before clipping and that’s not really reflected in the THD number@stoutblock, point taken about the Hirsch comment. I still can’t believe that anyone today finds THD to be a valuable metric.
You and Amir are welcome to believe whatever you will. My experience and that of more than one audio reviewer friend is they can make subtle improvements in audible sound quality.
FWIW, I also have dedicated 20A lines going to my listening room. Only sources are used with the conditioner.
Ah, the oft-misunderstood signal-to-cash ratio.I find the extreme lightening of cash from my wallet creates a euphoric light headed effect that enhance the listening experience.
I suspect that THD is often measured with signals that are too high, where noise and other low-level nasties are masked. More testing at small (and very small) signal levels might be more revealing, especially in power amps. I think Nelson Pass said something to the effect of "if the first watt is rubbish, what's the point of another 99 of 'em?" Yet the lab guys seem to love measuring everything at full output.THD is kind of a joke. The best sounding gear I’ve heard had some of the worst numbers. Could just be my bad ears or it could be that the numbers are always so small that matters little, or that distortion we readily hear is at a frequency extremes right before clipping and that’s not really reflected in the THD number
I had a weird and random noise problem with my system for many years that was very difficult to chase down. I was able to do things that made it better but never eliminated it. I routed interconnects, speaker cables and power cables carefully. I raised cables off the carpet. I managed the grounding between the components. All of this actually helped a lot but random problems still raised their ugly head. My listening room had carpet and I noticed the problems tend to be worse when static electricity was high in the room. In fact, static electricity tended to be high throughout my home at times. The water coming out of one upstairs faucet would give you a little zap when you would first wash your hands.
Then one day I was doing some gardening and mistakenly bumped my grounding rod below the main panel and noticed the clamp was loose. It always looked fine but I did not realize it was loose until now. I spent some time and cleaned it up along with the rod and made sure it was well secured. I also installed a better clamp on the grounding wire coming out of the panels as I noticed it had some low current resistance. I had everything working very well to ground even with low current. I really had no expectations this would help with my audio noise problems but just wanted to make sure it was doing its job for safety reasons.
The amazing thing is after this panel ground repair the static electricity problems have totally disappeared in my home along with the weird random noise I would get in my system. So much so that I am less concerned about the system cabling and I’ve removed the temporary spacers I was using to get the cables off the carpet. I have had no problems with noise in the system since the ground rod repair. I don’t think the root cause of the noise was electrical grounding but was static electricity.
Yes, that would seem logical, but I'm not sure how much Amir really wanted to find any difference. Was there any RF on the distorted mains sinewave? Were any checks made to test the possibility of RF at the power input polluting the audio circuit? Of course it's no surprise to find that a mains waveform that isn't perfectly sinusoidal is still capable of producing the correct DC voltage at the output of a power supply. It would be a staggering revelation to discover that it did make a difference. But so what?It appears Amir's tests, despite showing big changes in SINAD of the AC side, showed no changes in SINAD of the actual audio output.
To get a "blacker background", facilitating more of the music to come through as some using power conditioner have reported, wouldn't the SINAD of the audio output necessarily have to improve?
I think a bit more effort to look for more subtle artefacts was required.Most people think they might work but no one really knows.
