Pjsjr - I'm fairly certain that the rubber mat that came on my XA is not original. it's black, heavy, and about 3/16" thick. I don;t think AR tt's came with mats like this.
I listened to more LPs tonight and there is definitely an audible difference with the new thinner mat (carbon fiber and felt) It;s at least half the thickness of the black rubber one.
I researched proper vta for the M97XE, and everything I could find said that it was designed to properly align if mounted in a headshell with no shims. The headshell on my tt appears to track completely horizontally on an LP, so I don;t really know what else I should check. overhang, according to the AR manual and protractor, is set OK.
other posts I have seen have said that the bottom of the cartridge should be parallel to the LP surface. The M97XE seems to be different, in that the design of the aluminum mounting bracket appears to be deliberately set to give the correct vta when mounted in a standard headshell mount - and there is no dimension on the cartridge itself that aligns horizontally with the LP when mounted in the headshell.
if someone has guidance on aligning an M97XE in an AR XA headshell, I would appreciate it. Otherwise, sound coming from the system sounds really great.
thanks - Jim
thanks - Jim
