savatage1973
Addicted Member
This is related to and posted in another thread regarding issues with synthetic vs conventional oil, but just thinking about it, wondered if anyone else remembered/encountered this stuff 30 years ago.
The only oil that I have seen that once you put it in, you can't switch back to something else was back in the 80's when ARCO (Atlantic Richfield) Graphite was sold. "Once you go black, you can't go back"--and this is not a racial epithet--the oil was a conventional motor oil with suspended graphite in it, so it was black right out of the bottle--the theory being that the graphite reduced friction and provided better lubrication and fuel economy. In reality (and I have torn down several engines that had it in them) is that as the oil broke down, so did the suspending agent and you have all of this graphite deposited on EVERYTHING internally, and if you went back to a conventional motor oil with detergents, the formerly suspended graphite got cleaned off of all the metal parts and became an abrasive, rather than a lubricant--so if you put it in, you had to be pretty religious about oil change intervals and continue to use it forever, or risk serious damage.
