That is a weird problem. I cannot imagine what would cause that squeal.My G-8000 has one and it is a problem. Shortly after getting my 8000 back from CDFixer many years back, I was treated to a high piercing squeal. I ran to the receiver and started turning knobs and flipping switches and could find nothing to stop the noise until I found the mic knob. It was all the way off and as I started to turn it up the squeal stopped. Perplexed, I left the knob turned up to about 12:00 and walked away. Within a minute or two the squeal was back. I turned it up and it stopped. You can see where I am going with this. Eventually what I ended up having to do is to punch an adapter into the mic jack. With time I found that if the adapter was about 3/4 of the way in the squeal was stopped on a permanent basis. That is how it lives, leaving me puzzled. CDFixer passed away before this appeared so I was unable to get this dealt with; so I live with it.
The Dynaco PAT-4 has a Microphone input that has a flat response. It can be used with a calibrated mike to measure your amps, or speakers. I've got mine wired to the RIAA so it accommodate a second turntable. Have not used the PAT-4 for a long time. If I do, I'd wire the mike input back to the where it was, as a mike.A high impedance microphone input seemed to be pretty common in the early days of Hi-Fi, now, not so much. Does your equipment have this feature? Do you use the microphone input on your Hi-Fi?
Example: Heathkit WA-P2 with MIC (Microphone) input
