Kreshna
...but I have to know.
My mains are JBL 120Ti (89 dB/watt/meter). My center is JBL 4410 (91 dB/watt/meter). For music, I'm going to use Sansui AU-7900 and Dynaco QD-2. For computer games, I'm going to use Yamaha RX-V663 AV receiver. I also need a DIY 5 channel speaker source selector to switch between the two. Finally, I need is a suitable pair surround speakers, and the "titanium dome theater" is good to go.
The surround speakers should need the following criteria:
(1) they should be more sensitive than the mains, because I will use Dynaco QD-2 for surround music. And the QD-2 surround output is pretty weak, so a more sensitive pair of surround speakers are recommended (if the surround speakers are too loud, I can always use the QD-2 built-in l-pad attenuator).
(2) they should have the same coloration as the mains, because I'll also play computer games on the titanium dome theater. In surround music and Dolby ProLogic sources, the surround speakers are used for ambience. But in computer games, the surround speakers are used for directional sound (from behind). As such, it is important that the surround speakers to have the same coloration as the mains, otherwise the sound will sound disjointed. I tend to agree with this article.
Ideally, of course, the surround speakers should be another pair of JBL 120T'si. But of course, such models aren't easy to find (most ebay sellers do not ship such large and heavy object overseas). However, I found out that JBL Titanium family have similar sound, similar coloration. For example, when I tested a pair of JBL L20T's, my first reacion is, "hey, they are just the smaller version of the 120Ti!"
Of course, the 120Ti's go deeper. Also, during cymbal test (my favorite instrument), the cymbals in L20T's sound louder but harsher. The 120Ti's are also 2dB more sensitive. But if you ignore the nitpicks, the two models sound really similar, especially the mid range. Both models have the same forward vocals, and they have the same sound coloration which frequency response curve simply can't explain.
As such, I guess the ideal surround speakers for me is either a pair of JBL 4412's, or JBL 4410's. Both models are more sensitive than the 120Ti's, and I bet they also sound similar to the 120Ti's. However, they are also hard to find. Again, most ebay sellers do not ship such large and heavy object overseas, and I live in Indonesia.
However, JBL 8330's are always easier to find than 4412's and 4410's. They also seem to be smaller and lighter, since the S/H cost to my country is cheaper. They also have titanium dome tweeter, so I do hope they sound similar to the 120Ti's.
However, frequency curve comparison isn't very encouraging.
The JBL 8330's have slight LF bump. This could be a good thing, because it gives strong bass impression (although fake) from behind, so I probably wouldn't need rear subwoofers. Between 1 kHz and 10 kHz, the jaggy pattern are almost similar to the Ti series. Of course, it is not exactly the same, but JBL 120Ti's and JBL L20T's have different jaggy pattern, and yet the latter sounds almost like the smaller version of the former, as I have explained before.
What worries me is the sudden HF dip around 15 kHz. So perhaps the 8330 doesn't sound as bright as the 120Ti's? Perhaps things like cymbals and shattered glass are not as pronounced as those on the L20T's? Anyone experienced with 8330?
Many thanks.
Many thanks.
