Given the dimensions you've provided, likely not. However, I'm certainly interested to hear other opinions on the matter. I've always used the same length, but likely when you start getting into longer lengths, in excess of 20' or so, there might be a difference due to the different "load", which of course will vary with the gauge of wire.More specifically, should it make any difference if one speaker's wire is 25 feet long while the other's is only 15 feet long? Would it be better to just make both the same length, even if one will have 10 feet of unnecessary wire?
Do not "coil" the extra wire though.
To me it's like using two different width tires on the same axle of a car...it works but why would you want to?
Hmm, well I noticed a small delay in one of my outdoor speaker zones, I have the amps in the garage then there is one speaker with about 5 meters of wire to get to the one side, and 200m to get to the other side of our fire pit area, standing in the center of the two i can make out a very slight echo even when i switch the system to mono, both runs are using heavy duty outdoor phone line wire (solid copper)
It would drive me nuts if it was in my home system, I tend to always have the same sized wires anyways, even if one side only needs 1/4 the other one does ill just roll it up.. I wasent to keen on having 200m of wire wrapped up for the fire pit sound though lol
(Peavey CS-800 with generic solid wood speakers with thick paint coating to waterproof them, Mounted up in trees... Sounds awesome out there hah)
