It has an adjustment but it supposed to be set up from the factory. I guess I'll contact them.If arm height is adjustable, the arm should generally be level (or nearly so). If arm height is not adjustable, that arm may not appear level depending on the height of the cartridge.
What do you need to contact them for? You can just adjust the small hex screw at the base of the tonearm if it's really bothering you; it'll take you ten seconds to set a new VTA.It has an adjustment but it supposed to be set up from the factory. I guess I'll contact them.
(...) Hopefully it doesn't mean the VTA is off?
A decent VTA and, probably even more impotantly, a decent SRA are the actual goals, while the arm orientation is secondary. But of course ideally every cart should be designed and manufactured so, that it provides a decent VTA and SRA under both level orientation and the recommended tracking force. Mind you, ideally!
But to give you an idea: Iirc, the most recent IEC standard recommendations for a decent VTA and decent SRA are 20° (+5° / -0°) for the VTA and upright/0° to 5° leaned over forward (i.e. towards a viewer in front of the turntable, the usual table/arm arrangement provided; or respectively like this "___\___", if the direction of groove travel would be from right to left, which would most usually be the case, if one would look at it from the right side of the table (*)) for the SRA. And assuming a regular Arm with an effective length of 230 mm, starting at horizontal orientation, it would take ca. 4 mm more height at the base to achieve a downward slope of just 1°, whereas for 5° it would already take ca. 20 mm (**).
So if there's just a slight downward slope in your particular setup, it's highly likely, that it's still easily within the standard recommendations - even more so, in case you deliberatily went for a slightly higher than the recommended tracking force for a higher tracking ability (people often tend to forget about the cantilever suspension being the second pivot in that arrangement...).
Greetings from Munich!
Manfred / lini
*) Alternatively you might find the SRA also often referenced to from the record plane, direction-of-groove-travel side, so that our upright instead would be perpendicular/90° and our 5° leaned over instead would be 95°.
**) Mind you, that this would only go for a 230-mm-arm, on which the pivot axis for the vertical motion isn't oriented perpendicular to the headshell angle. Whereas for a 230-mm-arm, on which the pivot axis for the vertical motion has been adapted to be perpedicular to the headshell angle, it would be a bit less than those ca. 4 and ca. 20 mm each, due to the effective tilting axis length shrinking to the cosine of the headshell angle times the effective length.
Just got a MOFI Studiodeck turntable and notice the tonearm seems to be on a very slight angle downward not the 90 degree appearance in relation to the record or platter I'm use to seeing. That said it does track and sound excellent. Hopefully it doesn't mean the VTA is off?View attachment 2163445
I believe that would suggest that if you use a standard S or J shaped tonearm that takes standard removable headshells, it would mean the tonearm should be parallel to the record surface, since these headshells have no "bend" in them. They attach pefectly straight. This should make it very easy to adjust the tonearm for the cartridge (assuming it's adjustable). On my one turntable like this I have to apply a very thick cork mat because the tonearm is already adjusted as low as it will go.The cartridge should be level in the head shell. If the arm isn't quite level but the cartridge is correct then don't worry. Looking straight on at the cartridge is it perpendicular to the LP surface? Thats important also.
Would it also be accurate to say, (...)
causing the needle and cantilever to kind of "swim up" a bit.
Fishead: Well, then we might as well go all the way and additionally mention, that altering the tonearm height for SRA/VTA tuning will typically at the same time also more or less slightly alter the adjustment geometry (i.e. effective length & overhang as well as the offset angle) and even the tracking force. So in fact one doesn't merely alter one, but several parameters. So if one has done that, noticed a certain change of the sound and would like to be totally honest, one also couldn't yet attribute that change to the alteration of one isolated parameter only.
Manfred / lini
