Yes exactly, if you pull to check with LCR might as well just pull and replace. At least that way you know your good.Oh those are original all right. As to whether or not they need replacing is another question. You will really only know if you measure them with an LCR bridge. But if you go to the trouble to pull out the cap to measure it, you might as well replace it as it's almost 50 years old.
Sounds wonderful! First amp I like as much as my B&K separates but it looks cooler and has a much more friendly interface than the B&K pre-amp. You have all original- don't you sweat that the caps could go and then cause other damage?I see one on the power supply board by the heatsink (C808?) with signs of apparent heat related aging.
How does it sound?
I have one all original that still works great.
I have the ability and experience to do any of the work. Have done many repairs and recaps over the years. Probably even have most of the parts around already.Sounds wonderful! First amp I like as much as my B&K separates but it looks cooler and has a much more friendly interface than the B&K pre-amp. You have all original- don't you sweat that the caps could go and then cause other damage?
If you are comparing to similiar quality amps then I'd be tempted to leave it be, though that one cap with shrunken sleeve (C808?) would cause concern. If this is your "first" amp then maybe you don't know how good it can sound.It sounds so wonderful
