westend
Audiopile
I think you owe us a confession.........you built that entertainment center, too, didn't you?
Nice work on the speakers, a very high quality build. I especially like the blue baffles, as others have said, kind of JBL'ish. I can see from the pictures that you are an experienced woodworker, the dust collection and DIY sawhorses are a dead-give-away.:thmbsp:
I had posted in your thread asking about the JM fiberglass board and I'm glad to hear that worked out for you. I am thinking about replacing the R-13 I used in my DIY speakers with the same kind of glass you used. Did you line the entire carcass or just certain panels?
Choosing the crossover points proved perplexing! (say that 5 times quickly) I ordered the Pyles and the Dayton crossovers at the same time planning on splitting the 625-5,000Hz range between the 5" & 8"mid's. When the order showed up the low range was designed for 8 or 4 ohm loads via a jumper on the board. Not wanting to harm my Marantz 2285b, I decided to use the 8" mid with the 12" woofer below the 625Hz cut off. Originally I had planned on about 2-3 octaves per driver with a strong mid section. Splitting the low range required adding a 1st order filter to limit the 8" somewhere above it's low end capability of 200Hz, so I targeted 250Hz. I think I'd like to try some 8" woofers in place of the mid's. As far as the insulation I lined everything except the front panel. I'm open for suggestions, I can easily remove individual pieces. Getting that blue front also caused problems. I purchased anodizing 2 step automotive paints and attempted to verify them as enamels (unsuccessfully). So I shot enamel primer and tried to top coat only to find out that the 2 step was lacquer. Not soo good! I finally shot some more automotive blue metallic over the entire mess and still have some reaction crinkles, but it's blue.:tears:
