bhebbel
Well-Known Member
Great movie.
Great scene.
Great song.
in my limited experience, i have found amplifiers that were operated within their capabilities sounded the same.
I agree with you that all amps should sound the same. If they don´t they are either not operating properly, or were purposely designed to sound "different". Their job is, after all, to amplify a signal, not change it.
.. at equal volume, while both amps are operating within their capable dynamic range. Why should one competently designed amplifier sound different to the next?
I can understand that a low power amp, may clip when turned up too loud and perhaps not able to handle the transient dynamics of the particular track, but at normal listening levels, don't they all sound the same?
Have you been able to tell the difference between amps in a blind test? Or do you find amplifiers vary significantly? How much of this is marketing?
Bob Carver, a man who knows amplifiers, 30 years ago demonstrated that even experienced audiophiles could not tell the difference and that amplifiers are designed to have a "house sound".
http://carvermk2.com/docs/Carver Stereophile Challenge.pdf
Read it and weep.
is it ground-hog day ?
.. at equal volume, while both amps are operating within their capable dynamic range. No. Why should one competently designed amplifier sound different to the next? I am not an designer, so I'll just say it is because they are not the same circuit, parts, layout, etc.
I can understand that a low power amp, may clip when turned up too loud and perhaps not able to handle the transient dynamics of the particular track, but at normal listening levels, don't they all sound the same? No.
Have you been able to tell the difference between amps in a blind test? N/A .Or do you find amplifiers vary significantly? Not nearly as significantly as preamps, but, yes. How much of this is marketing? How much of WHAT is marketing?
I'll let you know when I compare them to my Crown Studio Reference-II (damping factor >20,000)!
Uh, no kidding, this is indeed an audio forum. When the slightly doltish guy in the room keeps bringing up the same topic again and again and again, don't be surprised if a few start avoiding him. It's simply human nature.
