So I currently have a Sansui G6000 and a pair of refurbished OLAs. I love it, but I've heard the siren song of the famed double advent setup. I really want to get a second pair to experience this aural nirvana but there are inconsistency in the info I have found on these forums. I have a few questions about the setup:
1) the g6000 is rated at 65wpc. Is this powerful enough to drive the 2 pairs? I read one item suggesting that this receiver doesn't like 4 ohm loads. This leads to my second question:
2) is the preferred wiring setup in parallel or series? Ive read that both are right. Clearly, if it is parallel, then the 4 ohm load could be a problem, but if series doesnt give the right setup then I would have to do parallel.
3) if parallel is the preferred method, is it possible to achieve good results using a speaker selector with a protection circuit? If I understand this correctly, two pairs of speakers can be run at the same time, but protection only causes the reciever "see" an impedance of 8 ohm and not 4 ohm, right. Would this setup work?
I appreciate and welcome all comments and help. I am fairly new to vintage audio, so I am looking forward to hearing from you.
Thanks!
Thanks!
