Spasticteapot
Nuclear Liberal
I'm personally a big fan of unusual audio designs. Dammar and bits of foam can go a long way twoards a better sound system.
However, I'd like to see more objective and less subjective testing on this forum.
Here's a few suggestions:
1. For cables, provide inexpensive (but decent) cables (Canare Star Quad?) in addition to those reviewed when testing. Use identical high-end connectors. Cover both sets in a LOT of heat-shrink, so they appear identical. Put a stripe of red tape one one pair, and a stripe of white tape on the other.
2. For the Brilliant Pebbles, opaque bottles should be used - one empty, one full of assorted-sized small polished rocks.
3. For the "Intelligent Chip", two will be issued : One normal one, and one that is simply an empty box with a bit of PCB inside, ideally etched so as to appear identical. One will have a red dot on the top, the other a white dot. (I live in Wisconsin. Sue me on the colors.)
The results would then be tablulated by a third party, and the results would be published. Just like any other study.
I just felt the urge to share the line of thought that your response prompted. :thmbsp:
