KingBubba
"Too Much Stuff"
I have been working out an issue on a Pioneer SA 9500II and on the amp board there is a double PNP transistor, a 2SA798. I have removed it and replaced it on the boards a total of four times now and it is getting a little beat looking, to the point that I fear to have to test it or remove it again. I thought to look for a replacement, just in case and came up empty everywhere I looked.
Question one is does anyone know of a replacement for this transistor?
Question two is: is it possible to create a replacement for it by melding two separate PNPs into one.
The pin configuration is BCECB. By placing two transistors together and melding their emitters, would this be a possibility for a replacement should none exist.
