My 2nd sx9000 project didn't go as well as the first. Had blown fuses in both channels. When I removed the top to clean and Deoxit, I noticed what looked like a sticky beer / soda stain to the right of the transformer, right in the middle of the big caps. The caps themselves look good, no bulging or leaking, looks like this was a beer spill. After cleaning and new fuses, they blew again upon power up.
The stained area is void of any boards on top, but below the filter caps is the rectifier board. Upon removing it, it looks like it took a hit. There is black dried goo on the underside. The other boards appear to have been spared.
I'm a novice, have limited test equipment and experience/expertise, but I think I can handle replacing this small board, only has a few connections. I can pick up a rectifier board on ebay for a reasonable price.
My question is this - assuming it was doused while powered on, how likely is it that the damage would be limited to the rectifier board? I'm tempted to give it a shot, but if it shorting most likely will have fried everything else it's connected to, I'll probably be over my head and as good as these receivers sound, I doubt it is worth sinking too much money into.
Thoughts and opinions appreciated. Thank you!
