Ok folks, here is an update with some pics. My DIY RCM is not yet together, but today I found some 3" foam rubber RC Airplane wheels that I think will work. Tomorrow, I hope to have a mockup of the mechanism assembled. Here are some pics of some component pieces, including the homemade vacuum wands I made based on another posted design on the web.
The picture above is a crude non working mockup of the motor to platter arrangement for the record cleaning spinning machine I am building. The vacuum part is a separate hand held system. Parts Cost so far, flea market turn table-$5.00; Krups small table top Ice Cream maker-$10.00; Pair of 3" foam rubber RC airplane tires-$9.00, Misc screws and mounting hardware- $7.00; box to mount it all in plus a switch- cost not yet determined.
This photo shows the wash (black) and rinse (white) vacuum wands I made from narrow vacuum nozzles. I found this tip on the big DIY RCM link I Googled and copied it, but I tweaked the end caps. I cut up a white light switch cover plate to make two end cap pieces and epoxied them on. The pads are replacement Mo Fi cleaning brush pads, cut in two. These wands will work with a old cannister vac I got from the Goodwill store but Home Depot is running a hand held shop vac type for $20.00 that I may buy. The manual platter in the back ground is from a cheap Sanyo all in one stereo with turntable. Its not real solid. More about the record weight in a moment.
On a separate but related note, the two pics above show a hand held record label cover/clamp I made based on the design posted in a related thread here on AudioKharma. This is for covering the label and hand holding the album to preclean really nasty thrift store and flea market finds before doing a normal cleaning routine. Cost was $6.00 for the male and female clamping knobs from a local tool and woodworker supply house; $5.00 for the 2 each 4" round gray plastic electrical box covers from Lowes (or Home Depot), and $1.25 for the 1/4" C clip to hold the cover to the male clamp.
This is a home made record weight/label cover I will use on my RCM. Parts are another 4" gray plastic electrical junction box cover, a Driveline Gear Spline from Tractor Supply for $9.00 plus a plastic push in cap for about a $1.00, and some glue and black spray paint.
