Not to insult your intelligence, but are you sure all the speakers and sub are connected in proper phase? Red to red and black to black. If any of them are out of phase it will mess with the low frequencies first.
Yes, and no offense.
Get a used 2 channel system like the Denon UD-M30 (the best mini system in the price range) for around $150, or get a nice 2.0 computer speakers like M-Audio AV-40 for about $100, and you will hear a difference.
They are designed for music, and they are about the best in the price range, so your ears will be able to tell them apart...
Your HT is for movies, so enjoy them for what they are... unless you can return them.
I just have 2 speakers for HT. because music is more important for me...
I just said that the music, even the drums, sound fine with earbuds. So the recordings are not the problem.
In my experience, a real reproduced drum sound I grew up with a drummer brother) requires good to great-quality speakers with real low end and solid, clip-free amplification. It's this snare cracks that are the most demanding in my opinion. It doesn't cost a mint to get there, but you'll need to step each component up to get there.
Kinda weird that bass is a problem in a HT setup. I know drum thwacks can produce sound from low treble all the way down to midbass. So, rolled off treble can lessen the apparent attack. On the other hand, if the system produces slow, under-damped, one-note bass that can explain things too. I assumed that one-note bass got left behind with the 90s, but maybe not.
Peculiar.
This is a HTS (home theater system) as you said, not something designed for dedicated music playback. If a system is set up for accurate music reproduction it often doesn't excite the home theater crowd enough, they want exaggerated explosions, bullets whizzing by, etc etc. Overblown bass is the norm for HTS, but this can be excused as we don't have a reference on how a certain bomb is supposed to sound. But the same isn't true of musical instruments as you've found out. This is one of the main reasons you see so many here purchasing vintage gear that was designed when music was paramount, not bombs exploding on TV.
Band pass subs are still alive and kicking in the mobile world, just listen as the cars drive by thumping, thumping, thumping. It seems that the manufacturers have taken this to heart and are giving the kids what they want, loud booming bass, even at home, it's what they expect from their systems. My helper at work was worried he wouldn't have enough bass in his car system as it only had two 18's, yes that's two 18" subs. "Shakes head repeatedly while making the last statement."
Also, what sound mode did you use to listen to the Beatles CDs? If the receiver has a "pure direct" mode where all speakers but the two fronts are shut off that might be worth a shot.
Probably not.
I have Onkyo HT and the best stereo sound you would get is the "all channel stereo".
This lets all the speakers work in stereo mode. The 'pure direct" will only have the front L/R and the sub working which will not sound as impactful.
Play around with the modes and see which one sounds best for music and stick with it.
