SPL db said:Heck, some friends of ours not only had the garage drywalled & insulated, but they
also installed wayne's coating halfway up the walls, wallpapered the other half with
an oak chair rail around the center.
They even had sconce lighting in the garage with painted floors.
So I don't see any problem with drywall and insulation!
Scott
JDaniel said:Mine is insulated, and instead of drywall, has plywood walls. It looks good IMHO. I think the plywood is better suited for a garage than is drywall, as doors, tools, bikes, etc. can hit the walls w/o making any marks/dents. I have R-19 in the ceiling, R-13 in the walls.
As far as the mice issue, you either have them or you don't, regardless of insulation/drywall.
JD
Scott
