AAA3330
I think that I may have found a NOS AW2 Lp spindle that has the original rubber pieces intact. Is that even possible, as I had thought that they had all fallen off of these spindles by now. I've tried it out and it seems to work well. One thing that I noticed is that these rubber pieces have a small groove in the lower part as if perhaps to better grasp the lowest record to keep the stack straight.
I had previously repaired a spindle by using pieces from a tape recorder belt(2mm square by 6mm long). It works fairly well except that it doesn't always hold the stack perfectly straight. I'm wondering if the secret for holding the stack straight is perhaps in the grooves of the rubber component.
