More a comment than question-
I have two 1209 turntables, both serviced and work well. The anti skate on both never fully zero out; if I balance the tone arm to float at record height and set the anti skate to zero, the arm will move outward from the lead out position to about the middle of the record. From the mid point to the outer edge there is no anti skate evident. If I set the AS to .5 gram, the arm will move completely from lead out to the outer edge of record.
When I use a test record the anti skate setting seems to track tracking force with a conical stylus, but requires about half the AS setting with an elliptical. Normal for a spring anti skate system?
