Dual 1212 manual spindle dimensions
ants2au
Ants
Hi,
I have a Dual 1212 turntable that is missing the manual spindle.
is this the same size as say 1218 1015 1009 1019 1010?
Does anyone have the dimensions on one of these? I can make one on the lathe if I have to.
Cheers.
It's not that same as all those other models as some of them use a straight pin and others kind of a hat design.
The one you need should be straight and would be easy to make. It's 7mm by about 35mm but the length is not that critical.
