Dual 1214 Stop Arm ball bearing location?
Sechack
Was cleaning and relubing a new-to-me 1214 and a 4mm ball bearing fell out from somewhere. From the diagrams for the 1214/16 it might be under the stop arm somewhere? Anyone have a clear picture of where the ball should be installed?
thanks!
It's probably part no. 146, steel ball 4 mm, that sits in the support bracket for the idler (part 108), there is also a small spring that will eject it if you dont grease it well before assembling.
the ball is in place on the speed selector switch ie #146. Still looking
Here is a diagram of where it might be from... #255 under the stop arm?
Oh yes you are absolutely right, there is another one there.
Those seem to be the only 4mm bearing balls present. I will go check my 1214.
