Dual 1215 tonearm replacement
MikeUlfs
Hello,
I have a Dual 1215 (no "s") turntable with a broken tonearm. Is there another arm that'd be a drop-in replacement, or do I need to get another 1215 arm? From what I've seen, the black plastic arm was only on this model.
I may very well be incorrect about it being plastic, but it's a similar tonearm to the 1212. I've got no issues doing the work myself. I bought this turntable for cheap as it was used to pillage parts by the previous owner. Just trying to get it running, and the tonearm is the last piece I need.
This should fit your turntable. No affiliation. https://www.ebay.com/itm/1439529972...MI2fiArKvA8QIVCvSzCh015g0fEAQYASABEgIQXvD_BwE
Take a look at the service manual on hifiengine, it has all the part numbers and this looks to match.
https://www.vintageshifi.com/repertoire-pdf/pdf/telecharge.php?pdf=Dual-1215-Service-Manual.pdf
Also, if a particular part of the tonearm is broken, you can look up it's part number, to see if it's available at places like 'organ donor parts'
You can also look at the service manuals for other models, to see if they have matching part #s, if they look to have similar parts.
