Already some good advice on this thread, I'll add what my steps are for cases like this.
What will typically prevent a 1218 from turning is either the motor, the idler wheel, or the linkage that the idler wheel attaches to.
Lift the platter (you may have to remove the ring clip).
First, check the linkage -- I've overlooked this in the past, and it's one of the simplest things to fix. The linkage that holds the idler wheel assembly will have a circlip that holds a bushing on a post. The linkage should swing back and forth on that post easily. If the motion feels stiff or sticky at all, pull the circlip, clean/lube (light machine oil) the post and bushing and reassemble.
Motor: Try to spin the motor pulley with your fingers. Does it spin easily and spin for a few seconds after you let it go? If so, then the motor is probably okay (although you may eventually want to clean it out to help prolong its life and reduce noise). If it feels stiff and sticky, it definitely needs an overhaul. You can find more info on how to do that here on AK if you poke around.
Idler: If the idler wheel is rock hard and not pliable at all, just order a rebuilt one. If the wheel has some pliability, look at the rim -- does it look shiny or cracked? If it has visible cracks, order a rebuilt one. Does the ilder spin easily on its post? If not, it may just need some light machine oil on that bearing. Try engaging the linkage that turns on the motor and pulls the idler up against the pulley. There should feel like there's a decent amount of friction/torque between the idler and the pulley. If it feels like it's not gripping very well, see if the rim of the idler looks shiny and worn. If so, it's worth a shot at resurfacing.
Resurfacing the idler: This works quite often on Duals, but you have to do it carefully. Remove the idler by pulling off the little plastic washer that holds it in place (don't lose this! You will need it later.) I use a drill, holding the long bushing at the bottom of the idler wheel assembly in the chuck where the drill bit goes. Make sure the idler wheel is spinning perfectly true and evenly on the drill. Then sand the rim/edge of the idler against some fine sandpaper (I use 220 grit). You should see black stuff coming off it. Sand until it goes from gloss to matte. Don't over do it. Reinstall the idler with the locking washer. Every once in a while, the idler needs two shots at resurfacing. But you really need to be careful so as to not significantly reduce the diameter of the wheel.
Good luck.
